These temps seem a bit high....
Firat
Now as you can see my idle temps are like 40-45C acording to these 2 monitors but my Bios temp says 33C?????
on load at 4.7ghz i get around 65c on these monitors bios i get 55 c
the bios temps seem more accurate for me but im just confused
any ideas?
my idle temps go up and down from 39c to 56c....very weird
bios temp = 33c and gigabytes own monitoring tool says the same......this is the z68 ud7 with a 2600k water cooled
I've heard the UD7 reports the wrong info to apps like CPU-Z, are your voltages etc being reported correctly?
cpuz displays my voltages incorrectly soi i use gigabytes own programs which display correctly.
