FarFarAway
Frigging sweet Kit, will update soon
[B]Genie BIOS Settings:[/B]
[COLOR=red]
Genie BIOS Setting:
Exit Setup shutdown....................... - Mode 2
CLOCK VCO divider......................... - Auto
CPU Clock Ratio........................... - 8 X
- Target CPU Clock........................ - 4240 MHz
CPU Clock................................. - 530 MHz
Boot Up Clock............................. - Auto
DRAM Speed................................ - 333/667
- Target DRAM Speed....................... - DDR2 1061
PCIE Clock................................ - 105 MHz
PCIE Slot Config.......................... - 1X 1X
CPU Spread Spectrum....................... - Disabled
PCIE Spread Spectrum...................... - Disabled
SATA Spread Spectrum...................... - Disabled
CPU Feature:
Thermal Management Control................ - Disabled
PPM(EIST) Mode............................ - Disabled
Limit CPUID MaxVal........................ - Disabled
C1E Function.............................. - Disabled
Execute Disable Bit....................... - Disabled
Virtualization Technology................. - Disabled
Core Multi-Processing..................... - Enabled
Voltage Setting:
CPU VID Control........................... - 1.6V
CPU VID Special Add....................... - 101.65%
DRAM Voltage Control...................... - 2.23V
SB 1.05V Voltage.......................... - 1.15V
SB Core/CPU PLL Voltage................... - 1.55V
NB Core Voltage........................... - 1.61V
CPU VTT Voltage........................... - 1.58V
Vcore Droop Control....................... - Disabled
Clockgen Voltage Control.................. - 3.45V
GTL+ Buffers Strenght..................... - Strong
Host Slew Rate............................ - Weak
GTL REF Voltage Control................... - Enabled
CPU GTL 1/3 REF Volt..................... - 110
CPU GTL 0/2 REF Volt..................... - 110
North Bridge GTL REF Volt................. - 110
DRAM Timing:
Enhance Data transmitting................. - Fast
Enhance Addressing........................ - Fast
T2 Dispatch............................... - Auto
CAS Latency Time (tCL).................... - 4
RAS# to CAS# Delay (tRCD)................. - 4
RAS# Precharge (tRP)...................... - 4
Precharge delay (tRAS).................... - 12
All Precharge to ACT...................... - AUTO
REF to ACT Delay (tRFC)................... - 24
Preformance LVL (Read delay).............. - AUTO
MCH ODT Latencey.......................... - AUTO
Write to PRE Delay (tWR).................. - AUTO
Rank Write to Read (tWTR)................. - AUTO
ACT to ACT Delay (tRRD)................... - AUTO
Read to Write Delay (tRDWR)............... - AUTO
Ranks Write to Write (tWRWR).............. - AUTO
Ranks Read to Read (tRDRD)................ - AUTO
Ranks Write to Read (tWRRD)............... - AUTO
Read CAS# Precharge (tRTP)................ - AUTO
All PRE to Refresh........................ - AUTO
Clock Setting Fine Delay:
Ch1 Clock Crossing Setting................ - More Aggressive
DIMM 1 Clock fine delay................... - Current[14]
DIMM 2 Clock fine delay................... - Current[ 6]
Ch1 Command fine delay.................... - Current[10]
Ch1 Control fine delay.................... - Current[ 5]
Ch2 Clock Crossing Setting................ - More Aggressive
DIMM 3 Clock fine delay................... - Current[13]
DIMM 4 Clock fine delay................... - Current[ 5]
Ch2 Command fine delay.................... - Current[10]
Ch2 Control fine delay.................... - Current[ 4]
Ch1Ch2 CommonClock Setting................ - More Aggressive
Ch1 RDCAS GNT-Chip Delay.................. - Auto
Ch1 WRCAS GNT-Chip Delay.................. - Auto
Ch1 Command to CS Delay................... - Auto
Ch2 RDCAS GNT-Chip Delay.................. - Auto
Ch2 WRCAS GNT-Chip Delay.................. - Auto
Ch2 Command to CS Delay................... - Auto
Read delay phase adjust:
Channel 1 Phase 0 Pull-In................. - Auto
Channel 1 Phase 1 Pull-In................. - Auto
Channel 1 Phase 2 Pull-In................. - Auto
Channel 1 Phase 3 Pull-In................. - Auto
Channel 1 Phase 4 Pull-In................. - Auto
Channel 2 Phase 0 Pull-In................. - Auto
Channel 2 Phase 1 Pull-In................. - Auto
Channel 2 Phase 2 Pull-In................. - Auto
Channel 2 Phase 3 Pull-In................. - Auto
Channel 2 Phase 4 Pull-In................. - Auto
[/COLOR]
name='cybermaniac' said:what temps u getting on the latest?
[b]Genie BIOS Settings:[/b]
[color=red]
Genie BIOS Setting:
CPU Clock Ratio........................... - 9.5 X
CPU-N2 Ratio.............................. - Disabled
- Target CPU Clock........................ - 4750 MHz
CPU Clock................................. - 500 MHz
DRAM Speed................................ - 333/800
- Target DRAM Speed....................... - DDR2 1201
PCIE Clock................................ - 100 MHz
CPU Feature:
Thermal Management Control................ - Enabled
PPM(EIST) Mode............................ - Enabled
C1E Function.............................. - Auto
Execute Disable Bit....................... - Enabled
Voltage Setting:
CPU VID Control........................... - Auto
CPU VID Special Add....................... - 126.45%
DRAM Voltage Control...................... - 2.27V
NB Core Voltage........................... - 1.53V
CPU VTT Voltage........................... - 1.17V
Vcore Droop Control....................... - Enabled
Host Slew Rate............................ - Strong
CPU GTL 1/3 REF Volt..................... - 68
CPU GTL 0/2 REF Volt..................... - 67
North Bridge GTL REF Volt................. - 69
DRAM Timing:
CAS Latency Time (tCL).................... - 5
RAS# to CAS# Delay (tRCD)................. - 5
RAS# Precharge (tRP)...................... - 5
Precharge delay (tRAS).................... - 15
All Precharge to ACT...................... - 5
REF to ACT Delay (tRFC)................... - 33
Preformance LVL (Read delay).............. - 8
Write to PRE Delay (tWR).................. - 13
Rank Write to Read (tWTR)................. - 11
ACT to ACT Delay (tRRD)................... - 3
Read to Write Delay (tRDWR)............... - 8
Read CAS# Precharge (tRTP)................ - 3
All PRE to Refresh........................ - 5
DIMM 1 Clock fine delay................... - Current[44]
DIMM 2 Clock fine delay................... - Current[445]
Ch1 Command fine delay.................... - Current[756]
Ch1 Control fine delay.................... - Current[512]
DIMM 3 Clock fine delay................... - Current[44]
DIMM 4 Clock fine delay................... - Current[512]
Ch2 Command fine delay.................... - Current[756]
Ch2 Control fine delay.................... - Current[445]
Channel 1 Phase 0 Pull-In................. - Enabled
Channel 1 Phase 1 Pull-In................. - Enabled
Channel 1 Phase 2 Pull-In................. - Enabled
Channel 1 Phase 3 Pull-In................. - Enabled
Channel 1 Phase 4 Pull-In................. - Enabled
Channel 2 Phase 0 Pull-In................. - Enabled
Channel 2 Phase 1 Pull-In................. - Enabled
Channel 2 Phase 2 Pull-In................. - Enabled
Channel 2 Phase 3 Pull-In................. - Enabled
Channel 2 Phase 4 Pull-In................. - Enabled
[/color]
The evap is showing -58c/-60c under dual Orthos
name='Orion' said:4.75? badass. what cooler are you using again?
(im about to buy that proc, and i want to know what i can get away with.)
wait, what? -58c, as in "negative 58 degrees celsius"? NEGATIVE?
