B
BrownGhost
Guest
Wow, dude help me reach that GHZ
Wow, can you help me out im stuck at under 3 Ghz
Here is my setup
CPU Rate 9x
CPU Host ENABLED
CPU HOST FREQ 333
PCI-E 100
CIA2 DISABLED
Sys mem multiplie 2,66
DRAM TIMING Manuel
CAS 4
RAS TO CAS 4
RAS PRE 4
TRAS 12
ACT ACT DEL Auto
RANK WRITE 10
WRITE TO PREC 10
REFRESH TO ACT 0
READ to PRE 10
MEMORY PERF Normal
DIMM OVERV 0,200
PCI-E OVERV Normal
GMCh OVERV 0,10
FSB OVERV 0,10
CPU OVERV 1,400
Super PI: 1 MB Test 17.188 V 1.4 ? V 1.5
MHZ CPU 2,997
MHZ RAM CPUZ 888 Mhz In bios 886 Mhz
This is not stabel for gaming
My goal is 3.4 GHZ
and stabel for gaming also
Can you tell me where im not doing it right ?
Kempez said:Post your Conroe clocks here.
Conroe E600
Kempez:
Conroe E600 Retail: 3.6GHz (400 x 9) @ 1.65vcore, 1.6vmch , 1.4v FSB
Conroe E6600 Retail: 3.375GHz (375 x 9) @ 1.55vcore, 1.4v FSB, 1.6vmch
Here is my setup
CPU Rate 9x
CPU Host ENABLED
CPU HOST FREQ 333
PCI-E 100
CIA2 DISABLED
DRAM TIMING Manuel
CAS 4
RAS TO CAS 4
RAS PRE 4
TRAS 12
ACT ACT DEL Auto
RANK WRITE 10
WRITE TO PREC 10
REFRESH TO ACT 0
READ to PRE 10
MEMORY PERF Normal
DIMM OVERV 0,200
PCI-E OVERV Normal
GMCh OVERV 0,10
FSB OVERV 0,10
CPU OVERV 1,400
MHZ CPU 2,997
My goal is 3.4 GHZ
