Doreguul
this is my first attempt at a water cooled custom pc.
here are the specs:
Corsair Air 540 case
Gigabyte Sniper M5 board
intel i5 - 4670k ( delidded & running at 4.5GHz )
32 GB of Patriot Viper 3 DDR3 1866mhz running at 2000mhz 1.5V
Intel 530 240gb SSD
Western Digital Velociraptor 500gb
Bitfenix Recon Fan Controller
Vantec Hotswap SATA Bay
EVGA 780 GTX Classified Hydro Copper
Seasonic Gold 850watt PSU
Custom Water Cooling Loop with:
Swifttech MCP-35x pump
Koolance 380i cpu block
combination of enzotech / monsoon / bitspower fittings
1/2" ID by 3/4" OD Bright Green UV Tubing
Aquacomputer Aquabox Pro 5.25" Reservoir
Acool NexXxos UT45 280mm Radiator
Acool NexXxos ST30 280mm Radiator
2 x Cougar 140mm Hydro Fans
2 x Corsair 140mm Air Fans
1 x Slim 140mm Fan
Here are the pics:
Painted the frame
Cutting the new drive bay
Bay has been cut
Bent the false floor
Bent the floor and mocked the radiator/hulk in there
Video Card
CPU
SSD
Raptor
Motherboard
RAM
PSU
De-Lidded CPU
The Devil's tool
Green LEDs for Hulk's eyes
They Glow
Front without floor
Tidy front
Not so tidy rear
Almost there
On and glowing (I need to change out the red LED)
Done
Overclocked Screenshot (I have since turned it down to 1.26V @ 4.5GHz)
here are the specs:
Intel 530 240gb SSD
1 x Slim 140mm Fan
Here are the pics:
