TPC
The Taiwanese company Lian Li, known for high quality PC-Chassis out of aluminium, is launching a new series of cases starting with the PC-J60
The case measures 210mm x 507mm x 489mm (WxHxD) and has a complete aluminium construction. Having 7 expansion slots available makes it ATX sized motherboards compatible.
It is also featuring a PSU shroud from the factory hiding the 3.5"/2.5" bays and of course the PSU.
The whole case is meant to clean up your system but still maintain performance. Lian Li is giving the user a lot of space to work in the case. GPU's up to 41cm length and CPU coolers up to 16cm tall are just the beginning.
Lian Li made different kind of radiator sizes compatible too. You can fit up to a 240mm rad in the front and up to a 360mm radiator in the top. A single 140mm radiator could be fitted in the mid-plate too if you're savage enough. Making it optimal for a decent sized custom loop using not only one GPU i.e.
The MSRP is 200€ for the solid side panel version and 230€ for the windowed version.
Net Weight: 6.48KG
HDD bay: 3.5" HDD x5 / 2.5" HDD x1
System Fans:
(Front) 120mm Fan x2
(Top) 120mm Fan x3(Optional)
(Bottom) 140mm Fan x1
I/O Ports: USB3.0 x 2 HD Audio
PSU length: 210mm
Source
Net Weight: 6.48KG
System Fans:
PSU length: 210mm
Source
