temps....
whooosh1
Hi Guys,
Just wondered if someone can take a look at my temps and tell me if they are too high. I'm running an E6600 @3ghz on an Asus P5B Deluxe, with a Sycthe infinity. 333x9; Vcore set to 1.3750v in the bios (showing as 1.34v asus probe, 1.328v cpuz). I've got FSB termination voltage, NB vcore, SBvcore and iCH chipset voltage all set to Auto.
Temps (using Sp2004, on both cores):
Ambient room temperature (24c)
CPU up to 54c @load mostly 51/52c (coretemp/Intel TAT)
MB: 47c at load (asus probe).
I realise Core Temp and TAT are more accurate than Asus Probe, but I am a little concerned that asus probe is showing my cpu temp as 62c at load. What are your thoughts on this? is it too high, or can I just rely on coretemp?
Would also like you opinions on the motherboard temp (47c at load). is this far too high? Because of the size of the Scythe Infinity its going to be difficult to replace the stock heatsink system on the northbridge. I have added the optional fan, which seems to have helped (and hasn't affected my CPU temps).
(Its not very often that the ambient temperature is as high as 24c in the UK! I've also tested at 19c which obvously brings the temps down a bit)
I'm a newbie, so any advice would be gratefully received.
The CPU is fine but ypu may want to invest in a cheap thermal probe to keep an eye on the NB temps.
Those temps are a tad high for the low voltage level, but definitely far from worrying about.
I would try reseating your heatsink and reapplying with AS5 to achieve the best results.
