Hey, I have recently done some overclocking but I left it at a state were I found it was not 100% stable. So today I boosted the volts a little and have finally found a set-up that is reasonably stable. It passed LinX with 2048 MiB on 20 runs which I think is fairly stable (It fails however on ALL memory) however the biggest problem I have now found is that my temperatures have gone over 80 degrees
the cores were - 82,83,79,79 which I know is too hot (There are around low 40's for idle). However the fans were not at max but would probably be at what I'd generally run them at (Even with max fans it is still hitting 80 degrees under stress)
I am running water cooling with a large 360 radiator just for the CPU and so am surprised about hitting 80 degrees at this point, there is no air from what I can see in the loop and I'm pretty sure I got it all out while leak testing.
For my rig's specs, look at the notepad document enclosed.
My settings for the OC:
Ratio - 21
BCLK - 200
PCIE - 100
CPU Voltage - 1.38125
CPU PLL Voltage - 1.90
QPI/DRAM Voltage - 1.58125
IOH/ICH = All on auto
The rig is not very stable (as in it will fail 2024 on LinX and will occasionally crash in games) with anything under these volts.
So what advice would guys give me on where to go now? I am tempted to just go back to a stable 4GHz clock but that kind of makes me feel 'Why the hell did I spend 250 quid on water cooling then?'
All advice welcome as always
(The document is a little out of date so ignore the bits that seem a little out of place like the overclocking question on the CPU and which Raid to go for etc)
Ratio - 21
BCLK - 200
PCIE - 100
