Hi, i am about to buy this, and im wondering about heat problems and so on concerning my 3930k, i knew in my prev amd bulldozer cpu tht it got hot because of higher speeds.
but what about my 3930k? on intel, is it the same?. i got poor brandwidth on my ram atm only 8500mb/s 1866mhz but these i wanto buy does 20 000mb/s. and will they run at 2600mhz, do i hafto set down mhz??
i use Gigabyte X79 UD5 motherboard
heres info about the kit i wanto buy
[font=verdana, arial, helvetica, sans-serif]Team Xtreem LV DDR3 2600 Quad-Channel CL10 uses selected chips and passes 100% stringent testing. 2600 MHz speed rate with 20,800MB/sec transmission bandwidth and covered in the super slim aluminum heat sink, to lift the transmission speed and quality steadiness to another level.[/font]
[font=verdana, arial, helvetica, sans-serif]It is the only one to meet the extremely high standards of the 1T Command rate in the market, and its efficiency is 10% better than any other Quad-Channel memory![/font]
[font=verdana, arial, helvetica, sans-serif]Team Xtreem LV DDR3 2600 Quad-Channel is designated to exceed enthusiast’s high expectations by bringing them the ultimate OC experience.[/font]
[font=verdana, arial, helvetica, sans-serif]- Fully compatible with Intel P67, Z68, X58, x79-based DDR3 motherboards[/font]
[font=verdana, arial, helvetica, sans-serif]- XMP Ready[/font]
[font=verdana, arial, helvetica, sans-serif]- High frequency and Low latency[/font]
[font=verdana, arial, helvetica, sans-serif]- RoHS Compliant[/font]
[font=verdana, arial, helvetica, sans-serif]- Larger capacity:4 GB Kit (2GBx2), 8 GB Kit (4GBx2), 16 GB Kit (4GBx4)[/font]
[font=verdana, arial, helvetica, sans-serif]- Equipped super thermal conduction heat spreader[/font]
[font=verdana, arial, helvetica, sans-serif]- 100% Tested and Verified[/font]
[font=verdana, arial, helvetica, sans-serif]- Lifetime Warranty[/font]
[font=verdana, arial, helvetica, sans-serif]- Data transfer bandwidth 20,800 MB/Sec (PC3 20,800)[/font]
[font=verdana, arial, helvetica, sans-serif]- CL-value: 10-12-12-31 1T[/font]
[font=verdana, arial, helvetica, sans-serif]- Working voltage: 1.55-1.65V[/font]
[font=verdana, arial, helvetica, sans-serif]- PCB: 8 layer PCB[/font]
	[/font]
