Teacher's 3770K Z77 Build
[font=verdana, arial, geneva, lucida, sans-serif]Season finale on the new fig[/font]
the rig is tidy and clean as it is. If you're looking to do cable sleeving, I would instead just get extensions. FrozenCPU.com is where I mainly go for those but I believe Specialtech.co.uk will be better for you.
Hey people i was wondering if i pic your brains.
I have been having a single problem with my rig.
For some reason i would say 1 in every 3 boots the computer will not post after the Bios screen.
It simply hangs on the Gigabyte menu - i press reset and there are no problems.
Any suggestions? I believe i am running Bios F8
I've just thrown in the R3 fan controller, i am too ashamed to post the pic of how untidy the inside of the rig looks now. However running the system fans on quite now, much better.
Hehe
Are you overclocking? It sounds typical of a power issue (lack of volts).
