Taking plunge going to water cooling
murphy7801
Hi guys built PCs for years never water cooled wanted some input see if making any rookie errors.
I have an NZXT switch 810 MSI x79 big bang 2 and soon to have reference MSI gtx 780 or 2. To cool these I was going to buy:
http://specialtech.co.uk/spshop/cus...Universal-CPU-Watercooling-Kit-pid-18310.html
With the XSPC gtx 780 block and back plate
http://specialtech.co.uk/spshop/cus...ics-Card-Waterblock--GTX-Titan-pid-17655.html , http://specialtech.co.uk/spshop/cus...an--GTX-780--GTX-770-Backplate-pid-17656.html
I wanted to use compression fittings:
http://specialtech.co.uk/spshop/cus...D-Tubing--Black-Chrome-10-Pack-pid-18090.html
Now if I went for second blocked 780 I was thinking of putting 280 rad in front of the case would pump be enough is anything Iv overlooked?
a 420mm skinny rad to cool a Cpu and 2 Gpus? It's possible but temps will be quite high and fans needs to be running at higher rpms to cool it down. Go for a D5 RX 360 kit and then buy another rad for the front which could be another 240mm RX or Alphacool UT/Monsta rads. A 360/240 rad setup will easily run at 7v and 5v if you really wanted.
120's are better IMO. Better fans...
Go for thicker rads as you have the room and a skinny rad in push/pull will still be behind in temps vs a thicker rad.
