Kaapstad
Active member
T-REX
I just thought I would post a thread for this if anyone was curious as to what my latest PC looks like.
This is not supposed to be the best looking build but more of a workhorse so it could be quite rightly described as ugly.
I have used GTX 980s in the build for now as a stop gap but some of you who know me will be able to work out from the title (T-REX) what will be going in there when they are available.
This build has had a few twists and turns as I tend to use what works best so change plan as I go along. For example I was going to use a 900D case but when it fell to bits coming out of the box I decided to change to a LDV8 which is a very solid case.
I was going to use the DDR4 3000mhz in the pics but this kit konked out after a week so I replaced it with the 3200mhz Corsair Dominator Platinum kit.
Parts List.
LD V8 case.
Asus RVE X99 Motherboard.
5960X CPU.
Samsung 850 Pro 1TB SSD.
Corsair AX1200i x2 PSUs
Corsiar Black PSU Cable kits x2
Corsair Dominator Platinum DDR4 (4 x 4gb) 3200mhz
XSPC Twin D5 Dual Bay Reservoir/Pump Combo
2 x AX360mm Rads
1 x AX480mm Rad
XSPC Raystorm waterblock
EK Water Blocks EK-FC980 GTX - Acetal+Nickel x4
EK Water Blocks EK-FC980 GTX Backplate - Black x4
Monsoon Chrome fittings
Various Koolance quick disconnects
Primochill Primoflex Advanced Tubing 16/10 - Black x4
More to follow as I add parts.
Build Pictures.
OMG it's green Jim
But at least it is all Aluminium
Some parts (you don't get much with these cases)
Some Rads
Fitting two PSUs
In with the PSUs
Mobo in, it is a good job I won't see most of that red when I am done.
And in with the CPU
One block ready to rock
Add some RAM
Some pumps ready for action
How to get two PSUs running together, with a lead like this.
Tubing
The coolant even though no one will see it.
Only one SSD but 1TB is plenty
And some cards
Just add water.
All wired up, the NV Death Star is operational.
Early Bench Scores.
Heaven 4 @1080p
3dmark11 P preset
3dmark11 X preset
Firestrike
Firestrike Extreme
Firestrike Ultra 4K
Skydiver
3dmark Vantage X preset
Some benches like Unigine Valley and 3dmark Vantage on the normal preset are not worth running due to the huge CPU bottleneck.
Parts List.
LD V8 case.
5960X CPU.
2 x AX360mm Rads
1 x AX480mm Rad
Build Pictures.
OMG it's green Jim
Some Rads
Fitting two PSUs
In with the PSUs
And in with the CPU
Add some RAM
Tubing
And some cards
Just add water.
Early Bench Scores.
Heaven 4 @1080p
3dmark11 P preset
3dmark11 X preset
Firestrike
Firestrike Extreme
Firestrike Ultra 4K
Skydiver
