System instable since new RAM
jonnyfgm
I've had my system running for a long time now on a 960, OC to 4 GHz (200x20)
With this I had 3 x 2GB Kingston Hyper X 1.65V (9-9-9-27 i think)
I bought a while back for a friend 2 x 4GB Mushkin Blackline 9-9-9-24 1.5V for a rig he was planning, in the end he never ended up building it though.
So I was doing some video editing and the 6GB just wasn't cutting it so I popped the 8 GB in instead. It was fine for video editing, and for some gaming after, however after a few mins of folding the system was freezing up.
So what do we think is the cause of this? I havent changed the RAM voltage or timings, but they are set higher and looser than rated so this shouldn't be a problem right?
I think its because its now running in dual channel mode instead of triple as before, thoughts?
i would consider resetting the bios to default to see if it works at default to isolate any timing / voltage issues
if that fails, try one stick at a time to rule out a faulty stick?
try underclocking i first or overvolt which ever,
if that doesnt work take two dims out to force dual chanell and then stick the other two back in
RAM is running at 1600 MHZ, also I know both sticks are fine as i tested em when i got em.
Might try the BIOS reset, but if it does work doesnt answer whether running in dual channel rather than triple makes OCing less stable
yes it is, but i thought you could run it in dual channel mode without too many problems.
Am i best off just buying another 4gb stick?
well i decided to buy another 4gb stick in the end, hell you can never have too much RAM lying about
so i bought another 4gb stick, fitted it, put the voltage down to 1.5, knocked the CAS timings down to 9-9-9-24, and it froze on me again
I bought the same brand, model, timing and voltage of RAM, just didn't obviously get it as part of a triple channel kit, it should work fine right?
i didnt try it before playing with the timings, but i didn't really play with them, just set them to what they're rated to.
And I think I may have to wipe my BIOS and start the whole OC process again
well i've reset my BIOS, and the system is at stock.
I'm now in the process of overclocking again, I have got it linx stable, but not prime95 stable, looks like im going to have to go at least 2-3 voltage notches over what it was before. I know adding more sticks of RAM can decrease overclocking capability but can the same number of more dense sticks also cause this/
so i've got things to a 24/7 stable OC, problem is i need nearly an extra whole 0.1V of VCore to get there, does this seem normal?
