NeverBackDown
AMD Enthusiast
Bitfenix imo are better but personally wouldn't be my first choice of fans.
TheLastRebel.... You are going to have to make some hard decisions, and soon.
I've seen two threads now where you are asking for assistance and yet seem to be being contrary to the people trying to help you.
I get that you are planning and that you are not certain yet what cooler you will get, but that decision can also affect other things. For instance, if you were to get an air cooler, then you need a set of specifications to be met by whatever case you get to meet or exceed or else the cooler won't fit. Same thing if you go for an aio cooler, but the needs change. Likewise if you intend to go custom loop later on.
I think it would be really helpful for everyone if you could tell us what you have already got decided, what you need the build to meet (quiet? High performance? Something else? ), and what you own preferences are, so that we can actually assist you properly....
Edit: Kudos to NeverBackDown as well for his patience so far.
i agree with u and neverbackdown i think im gona go with a all in one and mount it like u said and maybe be able to get it in push n pull just maybe idk but fan wise idm a lil noise but i just dont want it sounding like a wind tunnel but i want great perfermance with desent pressure from the fans so i can use the same fan on my rad as my case surfie i allready have my case its a switch 810 and yes later on im gona do a custom loop its just atm i wont have enough to do custom loop as well as the build would it be over kill to only use the corsair sp120s on my entire case and the rad
I agree... and thanks for the kudos
Are you going to get the h100i or H320(have to order from outside US to get this, due to legal issues)? H320 already have great fans that are semi silent and the h100i has loud fans but perform better by a few degrees. For the h100i you could just slow them down and not worry about it if is to loud for you.
