Dicehunter
Resident Newb
Finally they are coming out with SP LED fans, Only been waiting a beard for these ^_^
No official release date yet but judging by Corsairs new GPU cooler I would hazard a guess that it will be a June release which will coincide nicely with the hot summer temperatures
Air Series LED SP120 and LED SP140 High-Performance Edition Static Pressure Case Fans
The visually striking Air Series SP120 LED and SP140 LED fans incorporate the award-winning design of Corsair’s SP series fans – a design that utilizes seven ultra-wide, custom-molded blades to deliver higher static pressure for radiators and heat sinks, resulting in superior cooling efficiency. Rubber mounts and highly reliable hydraulic bearings deliver outstanding cooling with exceptionally low vibration, noise, and turbulence. These new LED fans are available in 120mm and 140mm sizes with red, white, blue, green, or purple LED lighting which illuminate the clear-frosted blades with four vivid LEDs.
Source *Further down the page* - http://www.guru3d.com/news_story/co...0_unleashes_your_gpus_hidden_performance.html
Air Series SP140 LED
MSRP$12.99 single pack
$23.99 double pack
$23.99 double pack
$15.99 single pack
$29.99 double pack
Size$29.99 double pack
120mm x 25mm
140mm x 25mm
Operating Voltage7-12V
7-12V
Airflow57.24 CFM
49.49 CFM
Static Pressure1.6 mm/H20
1.17 mm/H20
RPM1550
1440
Sound level26.4 dBA
29.3 dBA
Connector3-pin
3-pin
