switch 810 case fans
Ya i just noticed before you mentioned. I assume sub decided to mess around with it:p
Also have to thank Surfie for mentioning it in his previous post!
And the sister thread to it over in the liquid cooling channel...
Honestly, the guy has the patience of a saint!
I did not mean it literally, no offense intended.
Though in all honestly you need to decide to yourself for your final choice. Water or Air, then, which fans? Will help me help you more.
well i agree there im hard headed lol im gona stick with those corsair fans cause there performance since yall recominded them and i kinda wana go water cooling due to the temp performance but idk if i should since i dont plan on overclockin
Well fans are settled then. Now that it is finally solved let's continue in the other thread.
Just make sure that fans are the quiet edition versions.
