unknownuser200
Case would be a CM storm striker (white and black windowed version of the storm trooper.
PSu would be a Ax1200 (leaving room for a second video card)
Cables would be Custom bitfenix cables (saying toms idea goes threw with the full single braided ones)
Motherboard would be an asus rampge 4 formula
Cpu would be an intel 3930k
Ram would be 16 gb of muskin redline 2133
Gpu would be a 7990 water cooled (hense large psu for room to double up)
SSD would be 240 gb Revo 3 x2 max iops (saying nothing better comes along between now and then)
Storage would be a WD Green 2tb (small amount of ram cache for quick data access)
Dell U3011 (30" monitor already own)
cool would consist of:
a Magicool MOnsta 140 x3 (104.2 mm thick rad(generic Feser monster knock off irrc)) this would be mounted in the front drive bays intaking from the front of the case YES it will fit width wise there is 1.2MM of clearance lol.Push pull fans
Fans ould be Noiseblocker 140mm Pk2s (1200rpm models ) these would be used threw out the entire case.
water blocks would be All Ek
res would be an Phoyba 250mm black nickle
Tubing would be tygon 7/16th
Crome bitspower barb 1/2 fittings
Mayhem Tharsis Red coolant
Fill port in the roof by exhaust fans
Bit fenix Red and white Led lighting pending the mood
Pump is undesided but i was thinking a D5 with the dress up kit
with ALL that said thoughts? this would be june or july pending the release of things and my money at the time
