Suggestions on a new Rig?
AverageNinja
Average Penis Too
Hello
-forummembers!
So at the moment I'm busy saving money for my new project, and I think I'm starting to get quite close, only a few more months (I think 2 or 3) and I'll be able to buy it!
Now I need suggestions for the hardware I'm going to buy, with a budget of 900 euro's.
I am probably able to buy the components without taxes, which will make the components 19% cheaper.
I will buy the components at: http://www.alternate.nl
Here are the components I know I want to buy.
-Intel core i5 2500k
-Aerocool XPredator case (Evil black or white).
-Corsair H100 cooling
-Random 1TB 7200RPM harddisk.
-Windows 7 Professional 64bit (Since I can get this cheaper than Home Premium).
Total: 377 euro's
So the components I'm not sure about yet are:
-Motherboard
-Memory
-Power Supply
-Optical Drive
-GPU
Those components can cost up to 523 euro's, but the components will be 19% cheaper.
Do you have any suggestions on what I should buy for this particular system?
It's main use will be light video-editing and gaming.
Any help would be appreciated.
For gaming i would suggest spending as much on the graphics as you can and then getting a psu powerful enough to power the cpu and graphics which are generally the most powerhungry parts ;]
And do you plan on overclocking the processor if so then stick with the h100 but if you dont then i would say to spend more of that money on the gpu ;]
