Suggested Card?
stevebarnes15
Hi guys,ive just fitted my reservoir into case,on my watercooling setup,and it leaves me 10" to play with at most for gpu.
Can anyone suggest a decent card in the £200 region that will fit?
Must have a good FPS rate,as i will be using as my gaming rig,and for folding also.
change your res. 10-1/2 inches means you could have a GTX570......
I would do this as well keeping F@H in mind as well
I've got a little play,but the units gotta go up a little yet,and don't really wanna have to move optical drive down to compensate for cable clearance, but i can live with that if i have to.
Aswell as leave enough room to navigate the tubing,as i'm unsure of where i'm gonna fit the pump yet,will have to have a look when it arrives.
Apologies for pic quality,but you get the picture.
