Scoob
Hi all
I'm new here today, but wanted to post a new topic based on my overclocking experiences last night.
This is based on my system, which at it's heart is a 2500k on an Asus P8Z68-V Pro motherboard.
Now, I've been running at 4.5 since the day I got this chip - very, very hapy with Sandy Bridge I must say.
At these speeds I can run wPrime without issue, leave Prime 95 blend running for hours. I can even run the massively demanding IBT high stress test without issue - though my temps get into the low to mid-70's - a good 10c higher than either Prime pushes them.
Anyway, these multi-core processors are great. We all know this. More and more games too are starting to utlise this. Fantastic
However, some games still won't fully utilise all cores, generally only pushing a couple of them. After some random game crashes with games who exhibited this exact behaviour - just pushing two cores - I decided to do some additional stability testing on my rig.
I ran Prime 95 for a while, blend, four threads, just to prove nothing had gone screwy with my OC. All worked perfectly. Next I chose to run only TWO threads and I set processor affinity to cores 2 and 3. The test failed within a few seconds! After a few more tests I could see that if only two (or even three, though it took longer) cores were pushed my machine was less than stable. I wondered if I was just having a problem with Prime 95 so I fired up the MUCH more stressful IBT - the same IBT I been running without issue for ages previously.
So, IBT, two threads, affinity to just a pair of cores...go. Within 10 seconds I saw the blue screen - a sight I'd near forgotten!
Well this was vexing...why would my PC be sooo unstable when only a pair of cores were pushed when the vCore was more than adequate for all FOUR cores to be working hard? Were my "idle" cores somehow unstable because there was too much vCore for the work they were (or weren't really) doing?
I tried giving my machine a bit more vCore...IBT = CTD. I tried tweaking things like SysIO etc. but that didn't help.
So, I had a machine that was perfecly stable in Prime 95 for hours and survived IBT without a hitch when pushing four cores, but when just a pair of cores were stressed - a more realisic "test" for many games - it failed badly.
This did now explain certain CTD's I'd been getting in games that generally just push two cores. I'd hear the fans ramp up, then the game would drop...even though I'd say I was rarely hitting more than 80/90% on two cores...troubling.
Ok, to cut my evening of tweaking short, I DID manage to sort things. Basically I'd been running an LLC of "High" - which is a middle-ish setting on my motherboard. However, with two cores being push I needed to set this to "Very High" to get any sort of stability. Just that one change made be 100% stable in all the test I'd previously failed - I changed nothing else, having reverted to a prior profile after the earlier changes to be sure.
So, during testing, I now see slightly higher vCore reported when all FOUR cores are stressed and somewhat lower when just a pair of cores are.
I do wonder how many other peoples "stable" overclocks might fail such a test as I've performed? A test that, I think I've proven, is likely more realistic in terms of actual gaming system stress.
I'd be interested to hear peoples thoughts on this - it did vex me for quite some time yesterday evening
Apologies for the long post, hopefully it wasnt' too dull for all my fellow enthusiasts out there
Cheers,
Scoob.
Cheers,
Scoob.
