Brwmogazos
ok after 2 dead P4C800E Deluxe boards i need to find out where on earth does the air slip through from, the intel cpu kit...
As you will be able to see in the following pictures, i have quickly-not carefully as i do every time, applied some seal string on the cpu kit and fitted it in the Asus P4C800E
both my boards have died from condensation on the back of the motherboard...
So please have a look and tell what am i doing wrong and where could be the possible area thats causing condensation might be in the cpu kit...
1
This is the dead board so its not clean as i had it sprayed with pcb laquer after my last p4C died...
2
the back plate orientated on the back of the board
3
the back plates clearance that the seal string has to fill after applied
4
After applying the seal string on the back plate.I always use extra seal string and i always use it over and over so i give it the worm shape and then apply it to the backplate.As i said i did this one quickly so where the two ends of the string meet i havent "connected" them well together+ i always apply loads of string where the wire of the heating element goes throug the string both outside the back plate and inside the back plate by covering all the red thingy that the wires are connected to the heater element, with seal string
1
2
3
4
