Computer crazy
I have the standard Sensei and would recommend it to anyone, very comfortable, fast sensor. I would personally recommend that over the rubberised and the glossy, but again it is your choice. They are great mice and there is a wealth of options to play
Out of the rubber edition or the gloss black, I think the gloss black would show up fingerprints etc really badly and wouldn't look glossy for long. The rubberised edition seems to use the same rubber finish all over as the normal Sensei uses on the sides. Personally the rubber is very smooth and doesn't provide much resistance although it does help to grip the mouse.
I would definitely look at getting the regular Sensai as the metal style finish is very nice however out of the two you suggested it would be the rubber personally.
Hope this helps
Hope this helps
