This Tutorial will show useres how to figure out their STEAM ID without even starting it.
Skill Level : Easy
Program Lang. : Ger.
1. Open your Steam Folder (for example : C:\Program Files\Steam)
2. Locate the Steam.log File. If you did not enable the Name Extension the file will just be named Steam and will have no ".log". Open the Steam.log file.
3. Look for a Number with the following pattern : X:X:XXXXXXX.
The number schould repeat over the whole Steam.log file (Screenshot).
This number is your STEAM ID.
For what you will need it ? Leagues like TWL or CAL want to have these numbers from you so that you can be allowed to play in matches.
-FalconFX
Skill Level : Easy
-FalconFX
