Dawelio
Active member
Hey guys,
So I'm in the process of changing my PC a bit and will be building it down to a smaller case as it's an mini ITX motherboard in an mATX case.
I have 2 SSDs, although I need a 3rd one for the faster loading times on the smaller ITX PC... and not sure which one to get or which one is seemed "good" etc.
The ones, I've found so far are:
Kingston SSDNow V300 240GB
Crucial BX100 SSD 250GB
OCZ Arc 100 240GB
Kingston HyperX 3K 240GB
HyperX Fury SSD 240GB
Crucial MX100 SSD 256GB
Corsair SSD Force Series LS 240GB
Anyone that you would recommend over the other?... as they are pretty much in the same price range, I wanted to ask you for your opinions on this etc.
Thanks,
Chrazey
OCZ Arc 100 240GB
Thanks,
Chrazey
