SpyBot Search & Destroy 1.4 RC1
NickS
w00tage! Imma try it out later! :o
Download: http://www.scanwith.com/download_soft.php?d=762&s=409
Original Page: http://www.scanwith.com/Spybot_Search_and_Destroy_download.htm
ScanWith.com said:
"If you see new toolbars in your Internet Explorer that you didn't intentionally install, if your browser crashes, or if you browser start page has changed without your knowing, you most probably have spyware. But even if you don't see anything, you may be infected, because more and more spyware is emerging that is silently tracking your surfing behaviour to create a marketing profile of you that will be sold to advertisement companies. Spybot-S&D is free, so there's no harm in trying to see if something snooped into your computer, too :)"
What's New in Spybot - Search & Destroy 1.4 RC1 :
· Added Opera folder profile directory
· Fixed default value handling in registry entry recovery
· Fixed always opening on settings page
· Fixed localization of IncludeServices checkbox
· Fixed status bar text after SysInternals scan
· Fixed Host Redirect fix result for duplicates
· Fixed another selection bug
· Added Save/Load View Report settings
· Improved proxy handling to allow @'s in username
· Protection of exclude lists against tampering
· Main app now can detect changes to itself
· New /unimmunize CLP
· Updated system startup database usage
· Made settings password dialog to masked
· Changed Immunization to use encrypted file
· Updated ActiveX & BHO icons
· Implemented immunize undo value
· Added uninstall confirmation dialog
· Added shredder confirmation dialog
· Update result icon for cache
· Updated availability of SysInts excludes remove option
· Now uses better server for first update contact
· Added button to stop update downloads
· Added VeriSign certificate (for additional contents check)
