Xrqute
As some of you may know from previous posts of mine that I'm in the process of doing some major changes to my system some for performance others to just make my rig look amazing and crisp.
An idea that has been floating around in my head for the last few weeks is to disassemble my Rad's, remove the cores from their housings and then spray paint the cores (or housings for that matter) to match the colour scheme of my build. I think it would add that next level of detail. (I've never seen a core colour different from stock unless it came form the company that way)
But then of course the questions start popping in my mind-
1. Is this just a flat out NO NO!?
2. Will the performance Non-effected, Major-effected or noticeable (yet tolerable)
3. Is there a special type of paint id have to use or would normal spray paint be fine?
