sound card
Mega
I am looking to get a sound card for my rig to create a 5.1 sound system with some existing speakers. I however am only looking to spend 20$-60$. I have no idea where to start so all help is appreciated.
What speakers exactly do you have? And what motherboard?
It's pointless spending much money on a decent soundcard if you dont have good enough speakers to utilise the card, and in most cases the on-board sound will be nearly as good as buying a cheap sound card.
I'd find it hard to believe your motherboard doesnt support 5.1 audio - unless it's 10 years old, so if that's all you're buying for then maybe rethink
i have a set of TEAK speakers i can get to work. my mother board does not have 5.1 as when i bought the rig it was on a small budget.
