Game Over
Ok I have a few questions that are probably going to sound very noobish to many of you. I could surf google for a while and maybe get some answers or ask here for some straight forward simple answers/advice.
I am not really up on the whole usb 3.0 but understand that it really speeds things up. The new rig OC3D hooked me up with is 3.0 equiped.
At this time the only things I use USB for are thumb Flash Drives, a usb adapter for my micro memory cards, keyboard and mouse. Will I notice any difference using the 3.0 port for my flash drives and adapter over the usb 2.0?
will any usb device get better performance through the 3.0 or does the device also have to be special 3.0 capable?
If I do use the 3.0 port, I will need to get an extension usb cable because the 3.0 is at the back of the pc, Can I use a standard usb cable or again, do I need some special USB cable.
I can understand using the 3.0 if you have a nice external drive or something but not sure Its even worth using for flash drives, I am assuming the the flash drives themselves are the bottle neck when it comes to moving info between the PC and Flash drive so a faster port would make no difference?
Thanks for any advice/input.
PS. The rig is running great, not one issue yet, have played many games maxed out and have had 0 lag or low frame rates. Looking forward to Destroying Battlefield 3 with her soon.
Photoshop and Aftereffects are so fast now.
