Luscious
Hi Tom!
I was hoping I could get your valuable input on a project I will be starting in the coming months (sorry if I'm posting this in the wrong place). I know you've looked at the E5 Xeons and are familiar with the case I'm looking to use for this water-cooled multi-purpose workstation. Here's the parts list:
The processors I plan to cool using a 120.3 in the roof using six Noctua NF-F12's in push/pull. The GPU's will be cooled with a 120.2 mounted in the bottom and a 120.1 mounted in the front, again push/pull. Water blocks are EK supreme HF. The bay res will be a white 4-port EK connected to a D5 pump using 1/2"ID Tygon tubing filled with EK premium coolant.
Now for the question: I'm using a total of 3 rads and 5 water blocks to cool roughly 900W of heat - will a single pump/loop be able to work with that much load or should I put the CPU's on one loop and GPU's on another? Should I spend on a 2nd pump? And if I do have dual loops, how well will a single bay res work with a dual loop as opposed to using a 2nd bay res?
Thanks in advance, and keep up the great work!
Cheers
- CASE NZXT Switch 810
 - MOBO Asus Z9PE-D8 WS
 - GPU 3x Asus GTX680-2GD5
 - PSU Corsair AX1200
 - CPU 2x Xeon E5-2687W
 - BOOT SSD 2x Corsair Force GT 240GB
 - STORAGE SSD 2x Corsair Force 3 480GB
 - RAM 8x 8GB Corsair Vengeance 1866
 - SOUND Asus Xonar Essence STX
Cheers
