Excellent prizes this year.
Just a small comment, you have the Coolink cooler installed backwards. If you look closer you can see that one side has fewer fins then the other, that side with the fewer fins is the intake, and the side with the denser fin array is the heat exhaust. So it should be rotated 180 degrees in order to be in line with the general airflow of the case... Not sure if it will work any better though.
So you blow heat over the part with the most fins? naaaaaa its fitted correctly
NOTICE TO ALL
Any more bitching, arguing or winding people up and you will be exempt from the competition if not banned from the forums.
A select few people here are ruining it for every body else and I really cant be arsed with it. The team at OC3D have put a massive amount of time and effort into this competition and I will not have a few idiots ruin it.
