Smoothing rivet heads??????
Rob_the_scot
A quick question the rivets on the front of a case when you pull off the front bezel, can I file them down to make them flush with the case??? or will it affect the build of the case.
I thought about making my own front bezel due to the old one being damaged but I need a smooth surface to work on and its just the rivet head that's stopping me.
Sorry if this is in the wrong section
if you file them down then they will weaken and eventually (most likely when moving the case) pop out and it will fall apart. your best bet would be to build up your base over them and work from that smooth surface instead.
Oki cheers for the info, need to rethink on what to do
