fromundacheese@live.com
I have 2 MSI GTX 580 Lightning Xtreme Editions SLI'd together, the top one registers about 1 degree hotter idle, which is fine, but under load it gets to be 10-15 degrees hotter, ALSO @ the same fan speed (both configured at 60% idle, the bottom one is running @ 2790rpm and the top - closest to cpu - is @2640)
There IS ample space between them (1.5 slots) and I HAVE tried designating the bottom one to be primary display with the top closest to CPU designated as the secondary or phys-x gpu, and it makes no difference.
There is a 200mm CM Megaflow blowing right on them both, more so on the bottom one, but that doesn't explain RPM difference.
I logged in one day about a month ago, and it was like this... It hasn't changed for better or worse since then, and they are both BRAND NEW and NEVER overclocked (yet).
They are running on an ASUS Maximus IV Extreme-Z Mobo, on non-NF200 slots, so I ruled the heat out from that, but I suspect the added heat could be radiating from my CPU cooler. So... Any help or thoughts on this issue would be appreciated (especially if this has happened to you).
