SuB
The Webmaster
Hello, as per my Signature, I have 2 580 GTX's on a loop using an EK Coolstream XTC 280 with push pull, through a Laing D5 Vario...
One of the cards is fine, tops out around 40 degrees under full load, the other however seems to be topping out at 57 degrees now, and can on occasion go crazy all the way up to 80~90 degrees.
At first I thought the issue was the motherboard chipset dumping heat into the top card because it gets quite hot, and had no fan on it. So that's now water cooled on the second loop.. no problem...
But the temps still seem high to me.. I'm in discussions with EVGA about sorting a replacement, but I can feel the 'we sent you a different card of equal or better performance' coming
which would scupper my SLI setup...
Can I just check with the resident H20 boys.. that XTC 280 should handle both the cards right? what gets me is that one card is so much hotter than the other, the bottom card stays at a stable temperature yet the top one seems to go nuts
It's been suggested I re-tim the card, but I don't want to break my warranty, + it's like a days work to drain, take out, refil etc etc etc...
Just want some advice from the local techs please.. I'm open to ideas, but I'd like to avoid doing 10 empty and refils if possible...
