SLI clocks Problem
TearinX
Im not sure if the core clock or memory clock is supposed to be like this but check this out.
I'm using EVGA Precision tool to see the clocks and temps etc.
On my GPU1 These are the settings:
Code:
hxxp://i41.tinypic.com/hug02g.png
CHANGE THE HXXP TO HTTP
On my GPU2 they are:
Code:
hxxp://i41.tinypic.com/2eeixyc.png
BUT on the overall read out these are the clocks it says it has.
Code:
hxxp://i39.tinypic.com/o6emo7.png
The GPU2 is running slower then it is supposed to. I havent overclocked any of the GPU's they are at the default settings.
Can anyone help?
My SLI setup is
2x EVGA 9800GTX @ 738mhz (core clock)
Windows Vista ultimate 32bit
and Vista says its enabled.
Code:
hxxp://i41.tinypic.com/a0av46.png
Unless you were putting some load onto the GPUs, I'm thinking that the second GPU is running slower because it's in an idling position. Put it on load (run a demanding game) and then check while the game is on.
Ok I will try with crysis and then post the results.
EDIT:
Alright thanks zak4994 I ran the game and the clocks became the same.
