sleeveing
you have to take the molex headers off unfortunately. youcan do this with a pair of tweezers or if you are fancy you can buy molex pin removers.
Go back t the main forum homepage, and down the right you will see a links bar. One of the links is a guide on how to sleeve your psu ;)
Yeah thats a piece of cake, use the same sleeving material that you will be using in the PSU cables. The SATA plugs are fairly easy to get off and then do exactly the same. Do you mean the SATA plugs on the PSU or SATA cables for HDD? Either way it still works. As for the IDE cable, that may get a little messy...but as long as you have a system whereby you mark the schematics of which wire goes where in the plug you should be fine. Are they round or ribbon IDE?
Yep its a piece of cake...I'll add that to the guide if you like. I will include it tomorrow as its 12.00 am here, ok?
woops my bad, I forgot to do that for you limqareb. Tomorrow, I promise!!! I was guide writing today, and plumb forgot :o
