marco New member Feb 16, 2013 #1 Hi, in a few months i will upgrading to 1440p, question: GTX670 2gb + Skyrim with HD mods, will it work ? currently runnig in 1200p a-ok.
NRG! New member Feb 18, 2013 #2 Not sure. Depends which mods tbh, you may have to remove some. TBH you'll get low fps anyway because 1440p is a massive res compared to 1200p and it's a bit much for a single 670. You will benefit from reducing the AA, you'll need it less anyway.
