Dawelio
Active member
Hello guys!
So I was wondering if you know where to get hold on those short cable kits from Silverstone, to their small PSUs?... there are 2 kits, that I've come across, the PP05 and PP05-E.
Being the PP05-E being the one I want, as they are the all black, flat cables. Rather than being like "normal" cables and not all black to the end connectors.
Now, I've found this one: http://www.ebay.com/itm/Silverstone...05&prg=11353&rk=2&rkt=6&sd=331019970303&rt=nc
Although, I'm a bit jeezy about ordering that one... due to being ebay and since I've learned not to skimp on the PSU. Due to it can fry your entire PC etc, I'm a bit afraid of those cables and thought I would ask you... if you know anywhere else to get them from?.
Also... for an mini-ITX system: i7 2600K 3.4GHz, 16 GB Corsair Vengeance PRO 1600MHz, Sapphire Radeon HD6950 2GB, H100i, 1 or 2 SSDs and the same for HDDs.
To all be in the Corsair 250D.
How big would you recommend the PSU to be?... 550, 650, 750 or 850W?...
Thanks!,
Chrazey
Thanks!,
Chrazey
