has any one had experience with the Silverstone FT04? specificity what 360 rads you can fit in and where?
i know on the silverstone website they show a 360 rad in the front but i cant see where it says what thickness it is, if it has enough room to run push/pull or if the dust cover can be fitted after the rad is in with the fans on the outside?
any help or speculation welcomed cheers
