Silverstone Fortress FT02
Hay11Mac
Morning Guys
Can anyone tell me if the silverstone fortress ft02 will support 2 x gtx 480's, as I know the motherboard is mounted the other way.
Also what is the air cooling like in this case..
Thanks
Hay
It will support it, and the cooling is pretty good but you wont get your watercooling in there Hayles as its pretty much just got room for the basic hardware and F/A else!
Thanks TTL
Can you recommend a case that is both good for Air cooling & water cooling.... I don't like the Corsair 800D
name='Hayleywow' said:
Thanks TTL
I warned you about the 800D didnt I........
Siravice is right. get the 840 if you just want to bolt it in. Or if you want to spend some money on mods get a Lian Li.
Look at the a70 and a77 both have new varients about, if you like the look of the Lian Li's then I should be able to help you out getting them water ready ;)
I have looked at both of them cases before..... the things I don't like about them, is silly I know, is the grill at the front with that fans behind.... would I or you TTL be able to change that somehow???
Other than that I do like the Lian Li cases
You can change the front grill if you have too but tbh thats where the second rad is meant to go. Take a look at HellFire & White Star. Both have top rads so it will give you an idea, the A77 is pefect for big dual loops. The A70 is better if you have to have an optical drive.
If you want to get creative then Id say the Lian Li's are better than the 840.
Is the FB the better one to get then???
Will you be able to do some mods for me, or know anyone I could get intouch with? thanks TTL
Yeah and that.....
Bitpowers topper, I might have the pump to, Heater killer CPU waterblock, need recommendation for the rest
sorry am at work at the mo, trying to send these from my phone that has a weak signal
Yeah and that.....
