CalVic
Member
Last week my 980 GTX popped a mosfet watching netflix, replaced with a Zotac GTX 1070 AMP edition. Won the silecone lottery with it as it's happily clocking in at 2088Mhz on the core and 9.4Ghz on the memory (Micron BIOS fix applied)
Absolutely thrilled with the difference going to a 1070 (I can play Hell Let Loose!)
I decided to use my Die Mate 2 today to delid my extremely hot 4790k (thermals at stock voltages on 280mm AIO).
At the same time, I also serviced the Artic Freezer II with a new gasket and cold plate.
I kind of regret doing it somewhat now (It's an excuse to get a 5800X).
Popped the chip in the tool, delidded it and cleaned it all up with alcohol using a plastic card to take off the old silicone. All SMD's clean and good looking. I'm not using liquid metal, so didn't coat the SMD's with varnish or tape. Re-applied the IHS with the chip mounted in the socket, ensuring it clamps in the correct place (not going to bother to reseal).
Booted her up and well.. Code 55 Memory not installed. Managed to get her to boot with one stick in, applying the old pressure trick on the loosely mounted water block. However, was the only time I got it to boot. I've done the memory hop trick, applying different levels of pressure. I've even remounted the CPU a fair few times and cleaned it entirely again with alchohol.
That is, until I noticed a bent pin on the motherboard. Game over, I think... until I went full key-hole surgery on the socket with some tweezers. I think I did a good job putting it back!
Having a bit of a breather...
Here's some photo's of the processs:
CPU Delid
Bent Pin:
Fixed Pin:
Failing after this, it 5800X and a new mobo
CPU Delid
Bent Pin:
Fixed Pin:
