Hello all
I'm looking to put together a shutdown script for XP. I have a device running off 5vUSB which the software for fails to terminate during shutdown. This leaves the device feeding off the standby 5v which is a bit irritating to say the least.
I'm guessing I need to knock up a simple batch file and add this to the shutdown schedule. If so, whats the shutdown command for an .exe and where's the editor for the shutdown list?
Or if there's an easier method I would appreciate a pointer in the right direction.
Thanks in advance
Thanks in advance
