name='clone38' said:Tower has now been lapped,never again god it took forever to do![]()
name='peteski' said:Master_G, those pre-conditions are exactly what would convince me that lapping is a good idea. No, not a good idea but a pre-requisite!
I would also lap anything that had a visible machining finish on it, such as on the base of some heat-sinks the machining marks made by the tool/cutter are very visible and detract from the heat sinks purpose.
When lapping any surface, it is not only flatness that counts - finish is very important too.![]()
name='peteski' said:When lapping any surface, it is not only flatness that counts - finish is very important too.![]()
name='Master_G' said:As the others have said, that is plain wrong, it is ONLY flatness that counts. That is why if a company laps their own heatsinks to a certain degree of flatness using a machine, there is no point in you trying to improve it, as hand lapping can never get close to the work for a machine.
You may be able to get it to look nice and shiny and reflective, but that doesnt mean anything in regards to heat transfer, only the flatness matters as the flatter it is, the better contact you get and so the better temps you get.
G
