kup New member Jul 25, 2010 #22 That's it. Also add the number of cores too. -smp 4 Click to expand... ...for a 4 Core system.
H Hay11Mac New member Jul 25, 2010 #24 you put these shortcuts on the desktop right???? Should I have added any flags to the GPU Client shortcut?
S SnW New member Jul 25, 2010 #25 name='Hayleywow' said: you put these shortcuts on the desktop right???? Should I have added any flags to the GPU Client shortcut? Click to expand... Yes or in a map if that is what you want. no need for flags on the GPU client(s)..
kup New member Jul 25, 2010 #26 Check the guides in the Guide forum for a full run through of installation and setup.
H Hay11Mac New member Jul 25, 2010 #27 What do you put in "additional client parameters" doesn't say in ur guide...... I Just pressed enter in the gpu client
H Hay11Mac New member Jul 25, 2010 #29 is this looking right to everyone???? CPU is getting a bit hot, as haven't got the best cooler on it at the mo...... Shortcuts work ok
kup New member Jul 25, 2010 #32 Still not quite big enough to read everything but it looks good. I'd recommend using HFM as linked in SnW's thread to monitor your Clients though. It's better, updated regularly and calculates bonus points for -bigadv and -advmethods.
H Hay11Mac New member Jul 25, 2010 #36 Steve???? Something I have just noticed, just loaded EVGA Precision and my GPU usage is 0% (whats all that about) can't be right surely?
S SnW New member Jul 25, 2010 #37 name='stevehat1' said: I think your GPUFolding2 is running a CPU client/WU Click to expand... It certainly looks like it, i think the CPU is doing both the WU's ... So that's why the GPU is at 0% at least that is what i think....
