Setting up RAID
BigAndy
Hi guy's!
Can anyone help me to set up my drives for RAID???
I have 2 drives:
HDD 1: Western Digital WD2000JS 200GB
HDD 2: Western Digital WD2000JD 200GB
I was reading about it on web, but not quite sure i will manage it my self, so if anyone have some spare time to help me, you are more then welcome :).
I have DFI Expert board.
Cheers
P.S. If i have correct info then drives in RAID configuration will give better results in benches, will it?
You have to do a full re-install of windows.
Enable RAID in the BIOS - presiing F10 when prompted and adding the two drive the the RAID configuration- select striped and default stripe size.
Now start the re-install of windows.
Pressing F6 when prompted during the first stages of the windows installation - making sure you have the RAID driver floppy at hand - the rest is self explanatory.
It's easy but there are a few extra steps that you have to do for it to work properly.
Dont forget people we need any score entries for 32m superpi :)
Just like Mav said and heres a link on how to do it which contains screenshots all the way, used it my self yesterday as I too have just set up a raid 0 array using 3 raptors on the nvida chip.
http://www.angrygames.com/DAGF-2.htm
This guy is a moderator on the DFI forums.
Zax, we need your help in the benchmarking sections - can you post your Aquamark 3 and 32m superpi results please mate - also if you are on sli now you migth be able to improve your 3dmark scores also.
Cheers my friend.
Mav
So it's mean i will loose all my data on main drive if i will reinstall Windows?
Haow about 2nd drive, is data safe on it? If yes i could moove all the files i need from main HDD to 2nd.
Cheers
name='jellybeard999' said:
the 2 drives you want to raid need completely formatting... so you lose all data on those drives
DOH! :$ Then i need save all data on 2nd PC before i start to set up RAID.
Cheers
