seal string?
  • Thread starter Thread starter nick25
  • Start date Start date
N
nick25
Guest
I often hear of seal string - is this only for the machs or the vapo ls as well? also where is the best place to get some dielectric grease if I don't want to use the stuff supplied with the LS.
Many Thanks.
Many Thanks.
I would have thought it works for both as its doing same job - see other link http://extremeprometeia.com/forum/showthread.php?t=561&highlight=seal+string if you do a search for dielectric grease (on this forum), I am sure Farnells sell it and over-clock UK in Wakefield
sw
name='nick25' said:
its just that it says nothing about it in the LS manual.
Not required for the LS! Thats a very clever design, the grease is a must for the Vapochill and the universal head kit does away for the need of the string.
thanks phil - when you say the grease is required do you mean the grease that comes with the LS or just some dieletric grease in general?
