Sdumpers NCE^3-Cascade
NoL
NCE? You'll figure it out later ;)
Sdumper, scott, has asked me to do a 2 stager, then wait, nope a three stager, so why not ;)
The parts list:
Stage One:
Another 3/4-7/8hp Tecumseh Rotary compressor
Chilly1 Cascade condenser
Capillary/TXV (TXV might not happen)
Plate HX Possibly, though might do a standard 1/4" in 1/2" depending on copper prices
And all that jazz of T's and pipework and filters and such
r507a
Stage Two: Sdumpers Rotary single stage de-commissioning
Chilly1 Single stage condenser, or the original condenser without fan in front of condenser fan
Temprite 304 Oil separator
Packless 1k-Burst Hand Valve
(Into the HX)
Capillary
Plate HX
r1150
Safety cut-off, relief, expansion tank, de-composite pressure relief
Stage Three: Tecumseh 1.125hp Rotary of 7/8hp Matsu****a Compressor (Need to check ultra-low temp application ratings)
Half of original condenser as desuperheater, plus large coil
(Into Second HX)
(Into subcooler)
Capillary to Subcooler and evaporator)
Kayl Evaporator on 24" Braided Flexible Line
r14 + r740
The casing, with room for NCE^3.
You can see the nice comparison to the old 1hp rotary that has begun a foot rest. There will be a huge condenser up front though.
Much more updates as we pay/play/build stage by stage ;)
Best be three circuits ;)
-125C Suerpi with quad core, maybe around there for load. Goals sub -100C which shouldnt be hard with an argon saturation stage. Shouldnt be hard without it! ;)
wow !
I hate to b a retard but are the square boxes witht 3 input / output lines shown on the 2nd / 3rd stages flash expansion chambers or the oil separators ?
God that took me a long time to even get close to understanding what was going on!
On the stage in the top left you have no low side. And you have the high side returning back into its self You cant have the refrigerant return back into the TXV hows the refrigerant going to get re-compressed? I have to see the way that turns out!
NoL hasn't put in the suction lines, but labelled them instead. The end too the evap is deliberately not there i assume hes got something special planned.
The diagram is pretty fiddly too understand but as far as i can see its just a normal 3 stage.
/waits a slap from NoL cos he's missed something that makes it different
Hey Adam :p I've gotta say this is probably the most hardcore build I've seen from you ever. Is sdumper trying to freeze the ...carrots?... off of a snowman? keep the sick toys coming and make sure to post more porn i mean pics!
Hey havent really updated any real place with this build other then BPC, haha sorry UK guys, I'll get this
posted up asap.
