Putting together a cascade for my friend Cpt.Planet. The aim is for a strong bencher for current Quads and future Quads. So, two nice Matsush17a rotaries, 3/4 hp each, 13cc, two of my large condensers stacked (though different this time!), a watercooled HX, 10 plate HX, 340 Temprite Oil sep with hand valve and capillary for oil feed, Chilly1 evap with mount, 36" braided flex, normal cutoff for second stage, 1 ton filters, expansion tank, and capillary on both stages.
Watercooled HX is 5ft of 1/4" in 1/2", with female 1/2" threaded ports for change-able barb size.
Some prelim pics of build so far.
Oh and Jake plans on casing this once its done.
First stage brazed up. Dual capillary with 8ft on each line of .031" diameter rapped up nicely
Brazed up completely except hand valve which should be here soon! Lookin good n quite good lookin
Expansion tank will be up top, safety device all installed, oil sep in, all basically ready to rock n roll!
All brazed up, pressure testing now, oil loop located to the back nicely. Expansion tank up on top.
