Cascade 5 (2 Stage GPU)
as talked about earlier i will be trying out some water cooling on the first stage DSH coil
here is the cooler i will be trying out its a coolmaster all in one unit i used for cpu 2 years ago
i have made up a stand for it so it will sit above the cascade
name='Thickbrit' said:
Now that's a new twist,very interesting,can't wait to see it.
you will see it thursday:)
just been running some tests with the water cooled DSH and i must say i am very surprised i ran the unit for 1 hour and
35c knocked off the temps from compressor to condenser
sorry about all the temp probs all over the images i was having a look at superheat as well
the white prob line is T1 going in the DSH and the yellow is T2 comming out
the pump is the same unit people use in there garden
the idea here is to take the cooler water from the bottom of the tank
and return the warmer water from the dsh to the top of the tank
and as the water cools it drops to the bottom
this has worked so well i am going to stick with this for a while
in this image you can see the loaded temps/pressure of the first stage
13bar / -50
this is by far the strongest first stage i have ever built and to say i am happy with it
would be an understatement
(the load is coming from a X6800@4900mhz/1.8vcore 32m run (more of this later))
before i went ahead and made up the gpu line set i wanted to load test
the evap
evap used in this load test is one of little devils chilly clones
o/s is just my desktop vista
the cpu is a X6800 @ 4900mhz
m/b asus commando
vcore is 1.8v vmod and droop tested with meter
load is super Pi 32m
T1 is temp taken with the temp prob taped to the outside of the evap
T2 is temp taken with the temp prob taped to the suction return about 10 mm away from the evap
full size image
http://www.net7.info/1/cascade5/loadtesting/fullsize/DSC00815.JPG
the shut off hand valves have work like a charm as well
i just close the liquid line with the unit running wait 1 min and close the suction return
turn off the unit and remove the line set with no charge lost
Started running some load tests with cascade 5 and a 8800GTX kindly lent by
Raja
Thanks man i owe ya one:D
In the tests i was only looking at load on the unit not bench results
The card was over clocked to 902 core @ 1.55v using riva
The cpu just ticking over @ 4.8
Load is future mark 3D03 which it completed fine
The cascade evap temp (measured 10mm from the evap on the suction return) did not move more then 1 deg during load and sat around -104/103
o/s vista but for the next set I will put xp on
here are 2x 15 sec movie clips
http://www.net7.info/1/cascade5/working/movie/
some images
http://www.net7.info/1/cascade5/working/still/
Somethings not right with the movies...FF opens up a load of code for me, but no movie.
Your rig is beautiful, and the temps are excellent!
Wtf,did you guys not hear the man,he said he has designed a removable/interchangable lineset with no loss of charge.Simply brilliant and brilliantly simple,outstanding work Bazx.Shame about it being too cold though,i actually always said a s/s was enough for gpu,at least for me anyway.
Truly outstanding mate, you have set the bench for us all to dream about with this setup.
well done baz seeing is beliving and i have seen this and it truly is an amasing bit of Kit.
