Right, A few days ago my trusty 40gb maxtor bootdirive had a fit and died on me. Its been hammering away on its last legs since. But im now in possesion of a 200GB SATA replacement (thanks to the worderfule ST guys
Now ive just got to install the dam thing.
So far ive tried:
Plug n play option - plug it in, boot from the old drive. All seemed fine, then diskmanager wouldnt left me format it.
Drivers - Installed the SATAII drivers off my ASRock disk, windows started loadign and never finished.
Fresh format - unpluged all bar the new drive, used the files from the CD, put onto a floppy for the extra drivers thing in windows installer. Gets to 'Copying files' and it sticks at either 7 or 9 %.
Ive tried running it at SATA speed via the jumper and still did the same thing.
Im thinking i might not have the bios set up correctly but the user manuals are useless.
Any help welcome
So far ive tried:
Any help welcome
