Trixx1992
I'm going to set up a full watercooling loop but I ran into a little problem:
I have this GPU : Sapphire RADEON HD6970
And I have no idea if a reference cooling block will fit on this (lets say the EK (6970) for example).
Can anyone help me out with what type of block I should use? (Is it the same as reference cards or not?)
My Sapphire HD 6970
As you can see this is not the normal Sapphire HD6970 shown below:
Normal Sapphire HD 6970
Stats:
Output 1 x Dual-Link DVI
1 x HDMI 1.4a
2 x Mini-DisplayPort
1 x Single-Link DVI-D
DisplayPort 1.2
GPU 880 MHz Core Clock
40 nm Chip
1536 x Stream Processors
Memory 2048 MB Size
256 -bit GDDR5
5500 MHz Effective
Dimensions 249(L)x123(W)x48(H) mm Size.
Thanks alot.
My Sapphire HD 6970
Stats:
1 x HDMI 1.4a
DisplayPort 1.2
40 nm Chip
Memory 2048 MB Size
256 -bit GDDR5
5500 MHz Effective
Thanks alot.
