Pricing remains unknown at this point.
I'd imagine adding 4GB more VRAM would cost a lot, and then there will be the price for buying a higher binned chip etc.
Triple screen 4K is the only thing I can think of that would take that up easy. Maybe triple 2650x1600 too lol.Why the hell would you even need 8gbs of vram on a video card?
Keep in mind intel's IGP uses system ram(not entirely but reserves a lot for itself). So its actually rather limited.
But you'ed need 2 3 or even 4 of them for x3 4k gameing and people over-estimate what actually uses the most vram, higher resolutions shure it use's more vram but not as much as people seam to think the main killer of vram is filters and AA and at those kind of resolutions those filters are unneeded.
You realise AA is "supersampling" which just means it renders the actual frame at X times whatever the screen size is right?
4k is literally, 4 x 1080p which is *exactly* the same resolution as would be rendered by 1080p with 4x AA. This is then scaled down and a bunch of stuff run on it so you get sub-pixels colour change smoothness so you don't get 'jaggies'.
If you have a 4K screen, chances are the pixel density is high enough that you don't *need* 4k. The pixels are so small, that you don't need to go into sub-pixel colouring to stop getting jaggies. This is why the high dpi phone screens look so smooth!.
This said, if you DID put AA on, it would, again 2x or 4x the resolution and create the sub-pixels stuff required to remove the jaggies.
So no, resolution isn't the 'main' killer of vram, but the memory required for 4k is still roughly the same as 1080p @ 4x AA or so. (probably slightly less due to no processing requirements).
Put like that, it's the product of a bit of a dick waving contest between AMD and Nvidia. ^_^But you guys do realise the main reason this card has 8gb of Vram is because the Titan Black has 6gb, right?
Well it could also be used to advertise... "As much memory as a Console!" or something of the sort to help make it earn more money. Which is impressive but not really needed as nothing will hit above 4GB as of now.
Very select occasions, and Skyrim is because bad optimization. Even then it isn't near 8GB lol. Like SuB said, its just the epeen factor haha.I've seen a Titan go past 4GB in BF4 at 1400P/1600P and also go to nearly 5GB in Skyrim with mods.
